Old Feb 21, 2009 | 09:13 PM
corfire's Avatar
corfire
Default Do daytime running lights help keep the headlights from fogging?
The question is for our Canadian owners or anyone else that has them. Do daytime running lights help keep the inside of the headlights from fogging. I just returned from a late winter drive because the roads were clear and the sun shinning. However the lights were fogging. I have found that tuning them on does reduce the fogging (heat). So, in the past I have considered adding a relay or two create daytime lights by turning on the lowbeams with the ignition switch. Again the question is: have the Canadians had problems with moisture inside the headlights?
