Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
permalink
03-29-2009, 08:17 AM
drhrsh
re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
7.) Then remove the remaining 6 or 8 screws holding the lower panel, some are hidden in recesses.
8.) Gently pry down on the panel and it will pop down. If it doesn't you probably missed a screw somewhere.
9.) Next remove the transponder ring (chrome and rubber ring) surrounding the key hole. To do this press in on the back disc (escutcheon) and the transponder ring will pop out. It has a wire connected to it and can safely hang out of the way.
Like
drhrsh
View Public Profile
Send a private message to drhrsh
Find all posts by drhrsh
