Originally Posted by slk32krazy!
i have to disagree with this statement. my slk32 was bone stock and the pump failed. after replacing it with the cm30 my issues were resolved until the temps hit the mid 90's in tn. s/c was cutting out after 1 burnout and a single 1/4 mile run. after installing the supercooler from tighed1 i cna burn the tires off run 1/4's and extended interstate blasts in excess of 140 mph with ZERO issues.
after following all of woody's threads on this issue it is crystal clear that the oem h/e is to small and coupled with an inferior pump will cook the s/c in all but the coolest of climates.
while the supercooler mod may not be the first step in fixing this issue it should be considered a first mod and some of the best $ spent
juts my .02 and experience
