Alternator bolt loose???
As I was replacing my headlight bulb, I noticed the bolt holding the alternator seems to be backed out based on the smooth and shiny portion I could see and the gap. When I went to tighten it......it would not budge. At this point I'm not convinced it is loose. Is there so much tension on the belts that I would need to loosen it before attempting to tighten? or is it the way it is on all xfires? I'd hate to find out the hard way...on the freeway if it backs out all the way. Thanks
