Originally Posted by ///SilverSaphRT6
I had my HID bulbs seated upside down (metal tube on bulb on top) and there was no light output on ground. Flipped and there was light....but since you have regular bulbs....just check seating like everyone else suggested.
I just installed Sylvania Ultra 4100 temperature-low beam bulbs and it's brighter, but made no difference in beam focus or pattern. Still scattered, difffuse low beams.
When I installed them there was a little tab stamped out of the metal base ring of the bulb and a couple of stamped indentations.
I installed the bulb with the little metal tab sticking straight up at 12 o'clock. After I fastened the clip (use needle nose pliers, a flashlight and reading glasses!) on the new bulbs, I rotated the bulb gently until it felt like it clicked into place.
When you say "tube" on the bulb, are we talking about the same thing?
It sounds like I may have installed them upside down, although I can't figure out how that would have an effect if the bulb appears to be seated down all the way. Maybe it's not.
Thanks! I appreciate the help.
