Re: Windshield surround and side strakes
You have to go in through the wheel wells and pinch the clips that hold them in place, there are 3 for each, and don't forget to run fishing line along the strake where it is stuck down to the paint. Also on the passenger side there is the washer fluid bottle inside the fender, that has 1 screw holding it in place, it then slides right out, once you release the coupler from the bottle to the fill tube. Its rather easy but takes a little time I just removed my front tires and the rest was easy.
