Re: ABS PUMP Keeps on running!
The wheel sensor is on the steering knuckle behind the rotor, on each wheel.
I'm sure there is a process to test the sensor with an ohm meter.
Do a search for the thread that has the copy of the repair manual, and search for the section on the brakes. It should explain everything you need to know.
BC.
