Old Dec 14, 2009 | 05:00 PM
kingkub57's Avatar
kingkub57
Default Re: ABS PUMP Keeps on running!
Check your power feeds, the wire that engages the pump may be shorted to B+ or an internal failure in a module keeping a constant B+, and like mentioned before, the ignition switch could be defective allowing an open B+ circut, but in short there is something that is shorted out allowing the pump to run all the time, it may be also a ground triggered circut, check out the wiring diagram, to start, good luck.
