Originally Posted by Teck-9
Is it possible to get the engine from a C43 AMG then get the ECU+engine wiring harness and Oil pan / pick-up from a newer E 430 that runs the ME 2.8 and Oil system that works for the Crossfire. Then have the ECU tuned for the 4.3 AMG engine. Also, does installing a new oil pan / pick-up require rebuilding the engine or just removal of the oil pan?
I don't think you can mate a ME2.8 ECU onto a ME2.0 designed engine. Hell you can't even really swap out engines on the ME2.8. I mean, use different engine that use the same ME2.8 ECU.
It would most likely be easier to get the ME2.0 ECU and maybe run a dual ECU running partials off he ME2.0 bridging it to the 2.8 then running the other functions that aren't included in the 2.0 on the 2.8
Just a thought, not sure how feasible that would be.
