Originally Posted by FiftyThree033
As much as these "Forums" are helpful, don't get caught up in the paranoia. The weak points of cars when discussed on "forums" always rise to the top and are repeatedly gone over.
Enjoy your car. Use the info found in these threads to help if you know there is a problem....then throw time and money at it.
My .02 cents.........
Steve
yes sir...it's just info.....surging could be a lot of things...throttle, crank shaft position sensor, IC pump sensor, IC pump.....and list goes on with all the sensors the car has....but, when the pump goes you will know it, and it won't leave you stranded. In fact, my sensor was bad, but got a pump out of it anyway....I don't fix what isn't broken....but, nothing wrong with preventive maintenance either...
