Thread: battery drain
Old Jun 30, 2010 | 11:00 AM
Learnin's Avatar
Learnin
Default Re: battery drain
Originally Posted by joe lonardo
Thanks very much Pizza guy.
I actually did pull the fuses and found that it dropped to .070 when i took out the 10 amp fuses for the dome lights, horn, and door lock. How long should I wait to make sure that all systems "go to sleep" before testing again? I tested by using multi meter with negative cable off and and putting meter in between cable and battery post
Joe Lonardo
Joe,
You might have already done this but you can type in, "battery drain" in the search engine and read some threads there on this subject. Seems like some people attributed their battery problems to trunk light....
