heli coils
After a bad experiance with a tyre company last year i have now found that they have stripped the bolt hole on one of the rear hubs.After searching the forum i came across heli coils, which is a threaded insert which threads into the hub and then the original size bolt screws into that.I was wandering if anyone has had experience with these and if they are as easy to fit as they look.I will be using a light duty loctite to keep the bolt in place for now until the better weather comes when i can sort it out properly.Thanks Paul....
