Old Aug 26, 2011 | 11:30 PM
MAKIII's Avatar
MAKIII
Default Re: Windblocker Advice for New Owner
Forum post "Windscreen Adamesh Breakdown" post from 3/24/2010
I have both th OEM Chrysler plexi windcreen and the Adamesh - here is what said on 3/26/2010; and nothing has changed my view since
Well it is a gray; windy; chilly (43 degrees) totally overcast day here in the Shenandoah Valley but had to try this thing out - so after the 2 minutes it takes to put on - drop the top and off I go. Over the mountain towards Charlottesville, VA - it got colder 39. Heat on and butt warmers fired up.
and I hate to admit - the windows were up - ouch - be kind, it's cold
Here my take on this windscreen:
  • 1st - it works better than the OEM plexi unit from Chrysler, a ton better - no but better.
  • Does it work as well as the 1 on my 97 Audi - absolutely not - in the Audi almost regardless of speed you hardly felt the air at all, it was almost like the top was still up.
  • Speeds under 70 - works well - not much air is hitting the back of your head
  • Speeds over 70 (but under 100) you feel the air, but not as much as the OEM plexi screen.
  • With the top up and the screen still in you loose a small piece of visibility at the top of the windscreen; and the view out the back appears to be darker, could be I need to readjust the seat, but since the visibility is not so hot anyway - I couldn't care.
  • With the screen in - the seats still go ALL the way back - so you DO NOT loose any space, thank goodness,
Overall - I would say that I am pleased with the screens performance - over joyed - not really - but it looks cooler.
