Old Sep 23, 2011 | 07:03 PM
PNA's Avatar
PNA
Default Re: Engine quit running, need advice.
Originally Posted by KPK
Thanks PNA. The mystery-no-start thread was what led me to this forum. I've read many of the posts in that thread, and have made a copy of the RCM fix. I'd still like to know if a bad RCM is likely in my case, since the engine cranks but does not fire. Seems like most of the folks with bad RCMs could not get the engine to crank.
I should have read your post more carefully.
Last time I had an issue like this (not with my Crossfire) I seem to recall there was no spark and it was the ignition coil. It's been a while though, so I could be recalling it wrong. I'm sure someone on here will pop on and see your symptoms and figure it out.
Best of luck.
