Old Nov 15, 2011 | 08:47 PM
32krazy!'s Avatar
32krazy!
Default Re: Johnson CM30 = Damaged Intercooler?
Sorry for the dumb question, but not owning a SRT, I am curious. Does the stock system run on engine collant? If so I assume it is cooled by the radiator before going to the pump and into the heat exchanger? What is the difference between how a hight pressure vs. low pressure system in plumbed?
the coolant resovoir has 4 chambers and the i/c and the radiator both flow thru them. by closing off the i/c from the tank it becomes a low pressure system and the radiator remains a high pressure system. and yes the i/c uses the engine coolant
