Cheesy Door Handles!
Mar 19, 2012 | 11:05 AM
permalink
onehundred80
Apr 2006
25,432
648
Ontario
Re: Cheesy Door Handles!
Quote:
waylander
wouldn't it be possible to get stainless steel tubing made to fit? Ok it won't have any grove/ridges etc but from an exhaust place should be (quite) cheap and a piece of cake for them to bend into the correct shape?
It is not bent, it's straight and the screws that hold it in place hold the door panel on as well.
Maybe you could screw it on from the front and hold the door panel as well. If the screw head went through the first tube wall and tightened against the second tube wall and a plug filled the first hole it may look so so but may be acceptable to some like that. A spacer over the screw behind the tube would be best to mimic the OEM set up and prevent over tightening.
Personally I'd sand and maybe cover the rough spots. My passenger side is just sanded smooth.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
