Old Jul 28, 2012 | 08:31 AM
velociabstract's Avatar
velociabstract
Default Re: Getting re motivated, random pictures
I purchased a dip stick tool to check the transmission oil, and to give it the look and sniff test. Running the car as I do had me waking up at night wondering if the fluid was getting burnt. Good news, I've never seen cleaner and sweeter smelling transmission fluid in my life! I purchased a new filter and gasket for the transmission pan that's going into the closet until needed.
Something I've seen with my frequent tuning is the leaner you go the more power you make. My tunes have been as lean as around 14 AFR at WOT. As we speak I'm at 334 hp at 12.2 AFR which is down from my peak of 359 hp at around 13.7 AFR. I most likely didn't go BOOM because after that particular tune I started using Sunoco 100 octane. I'm back to 93 now that my AFR's are in the lower 12's but will add some 100 or 104 for track days.
