Old Aug 16, 2012 | 09:58 PM
SparkieSRT6's Avatar
SparkieSRT6
SSB SRT6 405hp/401Tq
Default Re: Pricy Oil Change at Dealership
Originally Posted by alaxfire
HD ramps ? Heavy Duty ?
I have an old set of steel ramps, and I find it impossible to drive up on them.
I have a polished concrete floor in the garage, and those suckers just scoot away when I try.
Maybe I should try gluing some rubber strips on the bottom ?
I had the same problem as my garage floor is highly polished and even the rubber grip grips on the bottom of the ramps don't help. I drilled in a couple threaded expansion anchors into the concrete and just bolt a 1 ft long 2 by 4 to the floor in front of each ramp when i use them. This stops them from sliding. I keep them stored under a workbench when not in use and just leave the bolt attached to them.
