lower your seat 1 1/2" for $20, easy with pictures
Aug 27, 2012 | 01:03 AM
permalink
JesseJamessrt6
Jan 2012
1,098
SouthTX
I have been wanting to do this mod for a while. Thanks Waldig (again) for the starter info and to BlueStorm and Couv for their write ups
https://www.crossfireforum.org/forum/tsbs-how-articles/35738-lowered-seats-more-headroom.html
I have the srt6 seats.
There are many ways and parts to use to do this but I will write up what I happened to do today;
3-4 hours
parts and tools;
-1. 2 each 1 1/2" long (important) grade 8 bolts in 3/8" or 10mm diameter, 4 each nuts, 8 each washers, 2 each lock washers, 2 each fender washers.
-2. 3" metal cut off wheels (used 2 each)
-3. 3" pneumatic cut off saw
-4. primmer/sealing paint (cover exposed cut surface metal)
-5. razor knife
-6. 17mm open end wrench (seat belt bolt)
-7. E-12 external Torx bit socket (seat mounting bolts)
-8. 7/8" drill bit
-9. drill
-10. RTV silicone or rubberized undercoating spray
Basic parts with order of nuts and washers on the bolt
Remove the 4 each torx bolts (slide seat forward and backward to get to them) and remove the 17mm seat belt bolt under the black plastic cap
Unplug the wiring harness under the seat here
Grab the plug like this to release
JesseJamessrt6
View Public Profile
Send a private message to JesseJamessrt6
Find all posts by JesseJamessrt6
