Old Sep 19, 2012 | 02:17 PM
waldig's Avatar
waldig
Talking Re: OMG I'll be late for work
I plan on doing a flow test on the air side, then clean the core, then do a flow test again to see how much it was restricted.
I plan on doing the same on the water side.
I plan on doing a pressure test with freon and a leak checker and bubble check to see the site(s) of the leak.
Depending on the above, I may open it up to see the construction as I have a few thoughts on that also, whats new. Corrosion is a concern.
Wdy Engineers you know.
