Old Nov 26, 2012 | 11:46 PM
kingtj's Avatar
kingtj
Default Re: Here is some headers for you guys
I don't claim to be some kind of engineer with expertise in this area, but I have done a LOT of reading and researching on many car forums over the years, as well as buying a very expensive and well made set of long tube headers for a previous car of mine -- so I wouldn't say I'm clueless either.
IMO, it's not even as simple as saying the headers will give you an HP and torque gain "when properly done", because I think much depends on the displacement of the engine in question too.
Time and time again, I've seen people try to put long tube headers on cars with 6 cylinder engines and fail to get good results. Meanwhile, it's almost always the guys with the larger V8's who have good things to say about them.
Especially on a lot of the foreign sports cars out there like the Hyundai Genesis Coupe or some of the Nissans, long tube headers wind up generating a lot of "rasp" under acceleration too. It's just not a generally desirable exhaust note at all.
I'd love to see the dyno before and after results for these headers for the Crossfire, and I'm far from being the guy who would definitively tell you they "won't deliver results". But count me skeptical, based on past results I've observed.
These are a labor intensive and expensive modification to make for relatively little gain, too -- even if they're a success. I doubt I'd ever put long tubes on another vehicle of my own.
Originally Posted by oledoc2u
I have ran headers on my Camaros, and even had a set on 1 of my vettes. They will increase hp and torque when properly done. The problem I had with the vette was the compact install caused a lot of heat related problems. Plug wires, other wiring and tubing. You have to insulate for those, as well as the heat under the hood. XF's have even less room in there than the vette's I have owned. I can see why they would have to lift the engine for install, but what are the clearances with the motor set back down? You would have to show me at least the 30hp and better price to even fool with headers again. XF aren't old muscle cars with lots of room for headers and the problems that go with them...
