Thread: TPM light
Old Feb 17, 2006 | 11:18 AM
typhoon55's Avatar
typhoon55
Default Re: TPM light
Originally Posted by bobs
There's no way to "recalibrate" the system per se, but what he may have done was reset the system and made it re-learn the ID codes of each of the four wheel sensors. If it's done right, when the TPM light comes on, you should be able to plug a scan tool into the OBD-II port and have the car tell you which tire is low and by how much.
Take a look at your repair order. Did the tech happen to list which code the car was sending?
I did look at repair order - it stated system was recalibrated. It is evident that the tpm system may occasionally need to be recalibrated as others have also posted. I guess the tech was 1/2 right anyway.
