Re: 2005 Crossfire Spongy Brake Pedal
A little tip when using this kit. Remove the bleeder screw, wrap the threads with Teflon tape. Don't block the hole. This will prevent a leak around the threads while you pull a vacuum. Also, watch the level in the reservoir. If it gets too low, you'll suck air into the system. This is also a good tool for flushing old fluid from the system.
