Re: 2005 Crossfire Spongy Brake Pedal
[QUOTE=BoilerUpXFire;731429]If your car is a 2005, the rubber brake lines are about 8 years old, if I were you, when you are bleeding, make sure they are good, or be safe and replace them, then bleed...[/QUOTE
Good point. My 67 Mini Cooper had a problem with those when it was22 years old. The rubber brake lines were acting like check valves. They were so swollen on the inside, pressure could be forced through them to the wheel cylinders , but would not return, locking my brakes up.
