Old Jun 14, 2013 | 11:15 AM
Bill F's Avatar
Bill F
Default Re: Light out Indicator
Originally Posted by eruby
OK I'm stumped. Bulb out indicator only comes on when I turn the light switch. I found that it will come on when I just turn on the parking lights. I've been around the car - 2 front baby lights, 4 side markers, 2 back lights AND license plate lights all on and working. Stock lighting. What am I missing? Is there something inside like an ashtray light that will trigger the indicator? I will have to wait til dark to see that. Thanks in advance for help.
From the Owners Manual page 103, 11. Light Outage Indicator: " With the key in the ignition switch turned to the ON/Run position, an indicator light comes on. It should go out when the engine is running. If the indicator light does not go out after starting the engine, or if it comes on while driving, it indicates a failure in the parking light, taillight, stoplight, or low beam headlight.
The indicator light will come on when the exterior light fails. If a brake light fails, the light outage indicator will come on when applying the brake and stays on until the engine is turned off."
