Re: Autostick Transmission vibration at low speeds
LTD... should it be the autostick, i wouldn't be surprised as i use the heck out of it...
A. if it is the torq conv solenoid and or malfunctioning sensors... that in turn is triggering the rear brakes then i will feel my brake pedal FLUTTER... I don't...
B. should it be the (BAD) fuel then at each of the engine's power band should the irregular engine rhythm occur... it doesn't.
well folks i went to chrysler yesterday without an appointment, they were able to look at my problem until they realized that the XF tech was out sick!!! (this happened to me once before).
anyway the service manager was eager to take the XF out for a test ride... the best that i got out from him was a "HMMMMMM?!?!?!" that's it!
the XF tech is due in on FRIDAY so i was told to take it back then... no appt needed.
i will go back to mercedes benz dealer and try there. i wonder somehow/they would honor chryslers warrantee on this slk/xf.
As far as my XF symptoms, they are still there but like you folks said... it has lessened not as bad as the other day...
j
