xX MIKE Xx
hello gentlemen im interested in installing a push button start but i still want to turn key to the on/run position... Is it possible? and what wires would i tap into? im going to locate the switch between the mirror switch and the cupholder. thanks
This video will help you'll need to use the wiring diagram from the service manual. Personally if I'm going to install a start button I would want the button to control the on/run and start all with the button. using the Dei 2102T device the push start button will only work if you have the required fob near the car.
