Yikes ! 2005 Coupe HELP HELP HELP !
Apr 12, 2014 | 05:06 PM
18
permalink
onehundred80
Apr 2006
25,432
648
Ontario
Re: Yikes ! 2005 Coupe HELP HELP HELP !
Quote:
Highdollarcarguy
I'll start with a fully charged Battery. Replace the ignition switch and crank sensor. Hopefully I get a spark. if not I'll work backwards from there.
I searched for a similar problem with the pump and only found
this
, which is no help.
I would disconnected the plug to the CAB, this is done by lifting the latch and pivoting the plug out. Easier said than done, this has cured one problem before as I recall, inspect the connections. This unit has power all the time somehow through the 50w fuses.A sensor may be at fault telling the pump to run?
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
