Originally Posted by HDDP
Andrew, I beg to differ with you on this one. I installed the TPM in the Milano wheels and it works fine. It is secured by a piece of double sided tape on the inside and the stem nut will fit almost every wheel.
you very well maybe right.
but i remember another board member had to grind the inside of his rim in order to mount the tpm module.
here are the posts...
Originally Posted by pnsji
Looks like alot of people are asking me about how I fit my brabus, lorinser, and my mille miglia wheels.
I bought these wheels yesterday for $2,800. I just found out (the hard way) that my Tire Preasure Monitor Sensor (TPMS) does not fit.
No real surprised since I have to do custom work to make the TPMS fit my current Lorinser wheels as well. I just don't want to spend more money to make it fit. So if you want to install them on your crossfire, you would have to either do custom work, or disable the TPMS.
_________________________
...and the MOST important thing, make sure the wheel support TPMS. I had to do custom work with drill/dremel/etc. to create the groove so that you could install TPMS:
