Old Feb 20, 2015 | 07:56 AM
  #3445 (permalink)
BoilerUpXFire
Originally Posted by carl graham
Evan> I'm referring to the light that's located inside the trunk...it's located on the left side (sitting in the drivers seat) and is about 2' in length...it's not outside the car.. Carl
Carl I would recommend searching on ebay for festoon style bulbs and get as close to the size as you can, then bend the tabs of the fixture to make it fit. I have done this to add LEDs to several of the XFs I have had. If you want some usable light from it, make sure to get SMD LEDs with at least 6 actual SMDs per bulb, more if they will fit.
