Re: What did you do to your Crossfire today?
Did my first oil change since buying my XF & driving 3,000 miles. The FSS was showing 3,800 miles. I found an Auterra oil filter had been installed. Didn't look that bad at least it hadn't been crushed. A Google search indicated that it may have been put in at Jiffy Lube, so I may not have been running with Mobil 1. The Mobil 1 & Mann filter are in there now. Oil change went OK except for missing the drain container & ended up with a small oil spill in the driveway that has been cleaned up.
My XF was purchased from an independent dealer so there were no previous records.
