Old Jun 15, 2015 | 10:21 AM
BisB's Avatar
BisB
Default Re: Plastic screws holding in trunk panels
Looks like 180 has you covered. Once you start removing panels, you'll see it's easy. Very helpful to remove panels/trim using removal pry tools rather than a screwdriver, makes it much easier and no cracking/braking of panels. Not sure about the fuse number, you could inspect each fuse to look for a blown fuse. Good luck and hope this is the worse repair you encounter for a long time……….
