oledoc2u
The Poland pulley does not need shims.... You will have shims on the stock pulley.... As usual the Canadian is opening his mouth about something he doesn't own nor has ever installed himself. That pulley is suspect as well for failure. I would buy the scatter shield to protect your hood and belts... If you need anything, PM me... I no longer care to partake in the everyday misinformation given out here.... I just couldn't resist today... I will pray for forgiveness later...
Wow Doc. How do you know for a fact that the Polish pulley does not need shims?
I've installed four different pulleys on my SRT6 and every one came with shims except Rudy's 62mm which had the front spacer washer so you didn't need a shim.
