Old Jul 12, 2015 | 08:55 AM
ala_xfire
Default Re: Side Mirror needs repair
As far as I can remember to completely remove the mirror you have to remove the inner door panel and disconnect the wires to it and release the grommet.
Then on the outside you turn the mirror to the inner position, this exposes the two Torx screws which undone to release the mirror. This can be seen in the PDF on how to instal the indicating mirrors. This can be found in this sticky post
I
The sticky post 180 referred to is https://www.crossfireforum.org/forum...stallation.pdf
however, I think the door panel removal part is only to run the new wire from the turn signal to the mirror.
Could be wrong, have been before.
