Old Aug 12, 2015 | 03:38 PM
  #120 (permalink)
HOT FIYA's Avatar
HOT FIYA
Default Re: NEW LED guide for the cars - March 2015
You have to slide the old ones sideways against a spring thingy and they come out attached to the harness. Unplug from the harness, plug in the new ones and insert back in place.
You'll see which way to slide them by trying, I have forgot which way. The new ones are made the same way so study them. You do not have to take the bulb and lens off to do it.
Alright thanks. So essentially the whole assembly slides to a certain direction and then pops out?
***Edit: So I actually just went out to my car and was able to figure it out. Well, the left side at least.....lol. The left side tag light assembly came out with relative ease. The right side seems like it will need some persuading in the form on a small flathead screwdriver to break it loose. Anywho, I plugged in the left side and got it popped into place and it works flawlessly. Hopefully i'll get the right side unit in place this evening once I have access to a screwdriver.
