Old Aug 13, 2015 | 05:40 PM
  #124 (permalink)
gp1200x's Avatar
gp1200x
Default Re: NEW LED guide for the cars - March 2015
Originally Posted by Adrian_X
I solved the shadow issue by cutting new notches into the XB35 5500K bulbs. The new notch is the complete mirror image of the original notch, which still sits the bulb in the clip holder properly without issues.
Image shows my HIDs after the modification.
Are using using the bulbs with 35W or 55W ballasts for your low beam?
I'll look at the bulbs tonight but I thought they had a protruding tab on the bottom that locks them into their seating position placing the anode on the top casting the shadow on the bottom. Are yours locked into that reversed position or is the spring tension just holding them against the mating surface.
Also are you using the Morimoto ballasts too?
Thanks
