Old Jul 4, 2006 | 03:09 AM
xfire1's Avatar
xfire1
Default Re: Autostick Transmission vibration at low speeds
adoni
you described it fine... see i understood... really what isn't clear is my brain... heheheh... getting too late here... anyway...
i know exactly what happens when i enter a turn from... 3 ..i slap it into 2 ... it stays in 2... doesn't shift into 1 it kinda floats where the rpm is too low... no torque or bite that's when i know i should have shifted it earlier into 1!
my tranny is nicely self-programmed... the tranny can be reset... re-taught... look below where i posted the MB recommendations... follow that sequence they describe to their techies to recalibrate the tranny... NOW, i don't have a tranny temp gauge to see the rise in temp intervals as they are describing... but i used the engine temp gauge and or stopped every 1 minute hoping i would achieve the required tranny temp levels...
also there is a way to reset the engine's computers by pressing on the accelerator pedal for a certain amount of time and turning the key on and off in a pattern... the engine also has a "memory" knowing if the driver has a heavy or light foot... so it anticipates in advance what we might do under certain load conditions etc...
that engine reset pattern is somewhere here on this forum... use the search engine...
if you can't find it... let me know... i have it in my other computer...
this can also be achieved by disconnecting the battery for a certain amount of time...
happy 4th
j
