Infamous top windshield molding.
May 1, 2016 | 09:32 PM
permalink
DTMenace
Apr 2006
2,509
206
West Chester, PA.
Re: Infamous top windshield molding.
Quote:
droopy26@msn.com
Does anyone know if they are different between the roadster and the coupe? Need one for my wife's 05 roadster Limited and possibly may have one but it's off a coupe.
Hi Droopy
There is a difference between the Coupe and Roadster top windshield molding, as well as the part numbers.
The Coupe # is A1936700087 and it has two rubber molding pieces, one on the windshield side and on that butts up against the roof line for fitment and insulation against the metal portion of the roofline. This prevents the rubbing of the plastic molding against the metal roof.
The Roadster # is A1936700187 and it has one rubber molding facing the windshield, since the top portion of the moulding rests against a thick rubber molding that surrounds the windshield.
There is a solution for you, if you want to use the Coupe molding, just remove the "top" rubber gasket with an exacto knife. It will adhere to the top of the Roadster windshield perfectly.
Good Luck
Dennis
DTMenace
DTMenace
View Public Profile
Send a private message to DTMenace
Find all posts by DTMenace
