Re: What did you do to your Crossfire today?
Xfire is in shop having front bumper cover painted. Replaced broken fog lamp (note - new fog lamps don't have the domed cover over the light bulb). I had to remove rear bulb housing and use with new front lens. Replaced all H7 and H4 bulbs. Cleaned inside headlamps with Methanol. Unfortunately, even after following process either a residue remained on inside or the outside is flawed even though smooth to touch and no improvement with polish. Also had Paintless Dent Removal tech fix dents (awesome job by Dent Genie - Brandon Willis). Ordered 74mm TB and MB cover upgrade.
