Re: Rubbing after wheel and tire change
Thank you immensely for your insightful reply. I am hesitant about grinding the bolt but I know it has to be done. Will I also need a front hub centric spacer in conjunction with grinding the bolt or the grinding alone will suffice? Thanks again for your help.
