maggy55
New brakes on rear, ceramic. Oil and filter change. Attempted coolant reservoir leak fix.
Curious about that fix (coolant reservoir?) hope it is working. I think this is a somewhat common occurrence. If the "bottle" on mine ever leaks again, I may VERY CAREFULLY use a source of heat to try to "weld" the plastic together. (used a hot glue gun last time, a few years ago, so far ok).
