Old Nov 30, 2017 | 04:27 PM
onehundred80
Default Re: Help Needed, How Can I Get New Keys Coded
There are some points here that need clarification.
You got a new key, how much did that cost if it cost a lot then you should be OK if not it is probably a wrongly chipped key.
You say the old Xfire fob started the car and so it should as it has a chip in the fob that matches the security code assigned to your car when it was made.
Forget opening and closing the doors that is a minor issue now.
When did the old key fob break? Maybe the chip fell out.
I would say that either the correct chip is not present, an incorrect chip is present or the SKREEM is shot.
Get rid of the Viper system and junk it, these cars are hard to steel at the best of times, who knows what the thieves did to your car.
