Here is a start
Vehicle Compatibility Chart
YEAR MAKE MODEL TRIM ENGINE NOTES
2006 Mercedes-Benz CLK55 AMG Base Convertible 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2005 Mercedes-Benz CLK55 AMG Base Convertible 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2005 Mercedes-Benz CLK55 AMG Base Coupe 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2004 Mercedes-Benz CLK55 AMG Base Convertible 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2004 Mercedes-Benz CLK55 AMG Base Coupe 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2003 Mercedes-Benz CLK55 AMG Base Coupe 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2002 Mercedes-Benz CL55 AMG Base Coupe 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2002 Mercedes-Benz CL600 Base Coupe 2-Door 5.8L 5786CC V12 GAS SOHC Naturally Aspirated
2002 Mercedes-Benz CLK55 AMG Base Convertible 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2002 Mercedes-Benz CLK55 AMG Base Coupe 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2002 Mercedes-Benz E55 AMG Base Sedan 4-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2002 Mercedes-Benz S55 AMG Base Sedan 4-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2002 Mercedes-Benz S600 Base Sedan 4-Door 5.8L 5786CC V12 GAS SOHC Naturally Aspirated
2002 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
2001 Mercedes-Benz CL55 AMG Base Coupe 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2001 Mercedes-Benz CL600 Base Coupe 2-Door 5.8L 5786CC V12 GAS SOHC Naturally Aspirated
2001 Mercedes-Benz CLK55 AMG Base Coupe 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2001 Mercedes-Benz E55 AMG Base Sedan 4-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2001 Mercedes-Benz S55 AMG Base Sedan 4-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2001 Mercedes-Benz S600 Base Sedan 4-Door 5.8L 5786CC V12 GAS SOHC Naturally Aspirated
2001 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
2000 Mercedes-Benz E55 AMG Base Sedan 4-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
2000 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1999 Mercedes-Benz CL600 Base Coupe 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1999 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1998 Mercedes-Benz CL600 Base Coupe 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1998 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1997 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1996 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1995 Mercedes-Benz E420 Base Sedan 4-Door 4.2L 4196CC V8 GAS DOHC Naturally Aspirated
1995 Mercedes-Benz S350 Base Sedan 4-Door 3.4L 3449CC l6 DIESEL SOHC Turbocharged
1995 Mercedes-Benz S420 Base Sedan 4-Door 4.2L 4196CC V8 GAS DOHC Naturally Aspirated
1995 Mercedes-Benz S500 Base Sedan 4-Door
1995 Mercedes-Benz SL500 Base Convertible 2-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1995 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1994 Mercedes-Benz E420 Base Sedan 4-Door 4.2L 4196CC V8 GAS DOHC Naturally Aspirated
1994 Mercedes-Benz E500 Base Sedan 4-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1994 Mercedes-Benz S350 Base Sedan 4-Door 3.4L 3449CC l6 DIESEL SOHC Turbocharged
1994 Mercedes-Benz S420 Base Sedan 4-Door 4.2L 4196CC V8 GAS DOHC Naturally Aspirated
1994 Mercedes-Benz S500 Base Sedan 4-Door
1994 Mercedes-Benz SL500 Base Convertible 2-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1994 Mercedes-Benz SL600 Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1993 Mercedes-Benz 300SD Base Sedan 4-Door 3.4L 3449CC l6 DIESEL SOHC Turbocharged
1993 Mercedes-Benz 400E Base Sedan 4-Door 4.2L 4196CC V8 GAS DOHC Naturally Aspirated
1993 Mercedes-Benz 400SEL Base Sedan 4-Door 4.2L 4196CC V8 GAS DOHC Naturally Aspirated
1993 Mercedes-Benz 500E Base Sedan 4-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1993 Mercedes-Benz 500SEC Base Coupe 2-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1993 Mercedes-Benz 500SEL Base Sedan 4-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1993 Mercedes-Benz 500SL Base Convertible 2-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1993 Mercedes-Benz 600SEC Base Coupe 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1993 Mercedes-Benz 600SL Base Convertible 2-Door 6.0L 5987CC V12 GAS DOHC Naturally Aspirated
1992 Mercedes-Benz 300SD Base Sedan 4-Door 3.4L 3449CC l6 DIESEL SOHC Turbocharged
1992 Mercedes-Benz 400E Base Sedan 4-Door 4.2L 4196CC V8 GAS DOHC Naturally Aspirated
1992 Mercedes-Benz 400SE Base Sedan 4-Door 4.2L 4196CC V8 GAS DOHC Naturally Aspirated
1992 Mercedes-Benz 500E Base Sedan 4-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1992 Mercedes-Benz 500SEL Base Sedan 4-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1992 Mercedes-Benz 500SL Base Convertible 2-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1991 Mercedes-Benz 500SL Base Convertible 2-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
1990 Mercedes-Benz 500SL Base Convertible 2-Door 5.0L 4973CC V8 GAS DOHC Naturally Aspirated
