amx1397
Greek to me. ! would any or all have the 4 bolt and replace the 3 bolt ,with no leaks?
These all have 4 bolt, and they use the same flex disc.
But, figuring out with has the same spline output shaft.
Since it looks like the bigger engines had the 4 bolt flanges, and probably larger output shafts in transmission, so would be isfferwnt spline counts.
Seals, if different could take to napa and say you want a seal to fit thus with a diameter of this.
Didn't some of those on the list have the same auto as what is in the crossfire?
Mine is the nsg370 manual.
Biggest thing if we could figure out the bolt hole diameter if the 4 bolt, then can double check for yoke flanges, then would have to find some or a business that has some that would send measurements.
