alexdc
Ok thanks. BTW Quaife does make an lsd for the SLK32. It's on their website. I just want to know if it will also work on na cars with the 6 speed.
I can only tell u what people say and that is when they got the quafie it did not fit,
the N/A, the crossfire the slk320 up to 2002 and the slk32 up to 2002 all use the same differential the slk 230 is different
as standard tranny goes, almost any diff you can get to fit will work because there is no tcu with standard transmission. we have put ratio's from 265 to 3.46 in standard transmission mercedes with that being the only change.
