CrossfireForum - The Chrysler Crossfire and SRT6 Resource - View Single Post - Driveshaft length
Old 09-15-2018, 01:51 PM
amx1397
amx1397 is offline
Default Re: Driveshaft length
Originally Posted by loggato View Post
Ok let me be more specific. I've swapped a 4.3L M113 V8 into my SLK230. the stock 230 driveshaft puts the engine too far back in the engine bay and there is no room for the throttle body tube or exhaust. now when I put the 6 speed manual from a crossfire in it (with accompanying driveshaft), it puts the engine where it should be. (basing this on comparing to pictures)
But now I am putting an AMG 5.5L in it, and going back to Auto, but I need to know if the Crossfire has a longer (automatic) driveshaft than the SLK230. my guess is it's about 2" longer but need to be sure before buying one.
with my 5.4 using the V 8 , the transmission mount fit in stock location ,so did the drive shaft ,, i would say if your slk230 was auto and now u are using a 5.4 with its tranny bolted to it the stock drive shaft should fit my stock drive shaft lasted 4 years with 300 runs down the 1/4 mile running in the 10's ,with over 600 hp so yea use it.
