Old Dec 8, 2018 | 11:17 AM
onehundred80
Default Re: Top Hyd. fluid level check
Originally Posted by ZERACER
When checking the level of the top fluid reservoir shoud the top be up or down or is there no difference? Should you wait until the pressure bleeds off or is it more accurate when under pressure? Does it make a difference?
The amount of oil in the cylinders is always the same except for the volume of the length of rod of those cylinders that have the rod retracted into the cylinder. Although on systems where some rods are retracted as some are extended it may be a saw off.
To be honest on the Crossfire system I have no idea.😉
If you can check the level with the top up and then down and see if there is a difference, if needed top it up from the highest level and look for a leak.
