ala_xfire
Just make sure you cover the intake tube if you have removed the engine cover, otherwise there should be no problem.
Keep away from the alternator, it has holes in the casting. Do not do it with the engine hot, warm is OK.
Drain it and remove the radiator and fan it will help do the front of the engine, you can flush the engine of coolant at the same time.
