Re: Can you clean your Crossfire engine with a power washer
Use a good degreaser and avoid high water pressure
With a pre spray of a good engine cleaner/degreaser the water flow from a home garden hose is sufficient
Apply degreaser to a very slightly warm engine and after cleaning and rinsing simply start the engine and go for a drive and the engine heat will naturally dry itself
Then once dry use an engine detailer spray
Mine recent Coupe now sold was this clean using this method
