onehundred80
The clocks are to indicate the date and sometimes the time the part was molded. The HC/PP is the material, a common material is PC/ABS which is a combination of Poly Carbonate and Acrylonitrile Butadiene Styrene, you can see why it is normally called ABS.
PP is Polypropylene, HC I do not know (typo?)
Are you sure you are not "AvE" that posts all those weird vijeos on uTube ?
